Gdetrailer
Mar 19, 2021Explorer III
speediq99 wrote:
I understand there are many parameters but I am posting to see if something significant jumps out.
I have one of these trailers and the opportunity to trade for the other one. We love both flooplans for their own merit.
I am towing with a 2021 F150 Powerboost. Tow vehicle is fine with both.
I was just wondering what will tow better.
Without disclosing much, I am getting terrible mileage with one of them.
One is a Palomino Puma 26rbss
Other is a Vibe 28RL
Thanks for the insights.
Trailer 1
Trailer 2
Maybe you need to define "terrible mileage"?
1 MPG?
2 MPG?
7 MPG?
10 MPG?
Those are monster RVs they are TALL and they are HEAVY and I don't care if you have the most "fuel efficient" hybrid F150 ever built, once you connect any trailer to it, it will no longer get supposed 24 MPG..
Towing takes considerable amount of "energy", keeping that weight at speed takes considerable amount of energy and typically most NA gas engines will get 8 MPG-11 MPG towing..
Your "Hyrbid" is not exempted from this fact and you have now discovered this by accident..
Your driving "habits" may also be a contributing factor in towing mileage.
You cannot drive like you stole it and get good "economy" towing.
That means you no longer do jackrabbit starts, you EASE into the throttle and start rolling gently. Pretend you have a fresh laid egg between your foot and throttle and you don't want to mash that egg into oblivion..
Once you stomp on the throttle the mileage game is all over and now you are dumping more fuel into the engine than if you had a large NA engine.
You also cannot expect to drive 70+ MPH and get good mileage, you are dragging a 11ft high "billboard" behind you, both TTs you have selected are crazy tall.. Speed kills fuel economy, try speeds of 55MPH instead of 60MPH-70MPH..
You want better mileage, you need to select a lower profile trailer, something 9ft tall or a bit less will get better economy..
Puma is 7610 lb GVWR, empty 6033 lb
Vibe is 9621 lb GVWR, empty 7096 lb
Here is specs for both..
"Puma 26RBSS
Specifications
Hitch Weight:610 lb.
GVWR:7610 lb.
UVW 6033 lb.
CCC 1577 lb.
Exterior Length:29' 10"
Exterior Height:11' 1"
Exterior Width:96"
Fresh Water:43.00 gal.
Gray Water:69.00 gal.
Black Water:34.50 gal.
Awning Size:21'
Vibe 28RL
Specifications
Hitch Weight:821 lb.
UVW 7096 lb.
CCC 2525 lb.
Exterior Length:34' 5"
Exterior Height:11' 2"
Exterior Width:96"
Fresh Water:40.00 gal.
Gray Water:60.00 gal.
Black Water:30.00 gal.
Awning Size:11' & 10' "
