blt2ski
Oct 14, 2020Moderator
Could be shocks, I would try first.
Another, is if you have P metric tires, or the HT ones, Its also possible those are too soft for the heavier hitch weight of the new trailer. So a set of LT C or D tires would help this too.
Not that i would swag this, but the rear springs may be worn. I doubt it personally. Going to a heavier version, ie instead of say 3000 lb springs, go with 3500 or 4000 lb rated springs. Fords are known for having lighter springs than one thinks they should GM had 3900 lbs for all 15 series versions. Ford has multiple from 3000 up to 4500 or there about.
ANy of these fixes are cheap compared to a new 25 series truck.
Marty
Marty
44,070 PostsLatest Activity: Aug 06, 2026
