joeshmoe
Aug 31, 2016Explorer III
Which Sikaflex?
Which model# is recommend when I install the awning to seal the bolt holes and brackets. It's a Carefree awning, so it has those aluminum plates with thru-bolts. Then the awning simply hangs on those. I want to run a nice thick bead around the top and sides of the brackets.
On Amazon, I see 221, 252, 505, 715, etc. Not sure which is best to use.
