serpa4
May 27, 2014Explorer
Which Timberens?
Timberen has two options: Severe Service-Slide-In Camper Or Salt Spreader (single), 8,000lbs Standard, 8,600lbs (numbers not reversed). The Severe get stiffer very fast and contact even w...
The Severe get stiffer very fast and contact even when empty. The standard are softer and compress more to reach max capacity.
My TC is under my trucks rating, 4,100 lbs, but when loaded and then insert the hitch extension, my boat tongue of 200lbs is sort of low.
I think the standard should be fine and I'd like the smooth ride when empty. However, the Severe service says slide in.
Your thoughts please.
