CincyGus
Jun 10, 2013Explorer II
I don't think there is a problem with aluminum skinned trailers as long as they are maintained well.
Here are my thoughts on the two skin types:
Aluminum can be dented more easily, much like aluminum siding on a house. It never rusts and is easier for the DYIer to work on than gel, smooth siding if there is a problem. Sealing the corners, around any cutouts and the roof is critical to not having leaks, rotting.
Smooth sided trailers have less seems since they are cut out and solid one piece per side vs. the aluminum skinned overlaying panels. They still require the same seal inspections in the corners, around cutoffs, roofs, etc. They are not as easily damaged by say a overthrown ball but if they are damaged, are not as easy to repair.
My decision to buy a smooth sided trailer basically came down to it being easier to clean (in my opinion) and to visually liking the looks better. Both types of trailers can llok wonderful for years and provide leak and rot free service for many years if properly maintained.
44,068 PostsLatest Activity: Jun 14, 2026
