SouthpawHD
Sep 02, 2015Explorer
gmckenzie wrote:Tony2238 wrote:gmckenzie wrote:
The diesel/gas question probably comes down to how much you expect to tow, and what you do with the truck the rest of the time. And personal preference. I like diesel but just traded mine in for a 1/2 ton gas as I didn't use it enough. I actually parked mine in the winter instead of abusing it with my short commute. So back to gas for me, based on what I do when I'm not towing.
You will add more than 1,000 lbs once you consider the propane tanks, batteries, water and hitch all become part of that total. Best to consider the gross weight rating of the trailer when thinking about towing. But an F250 diesel will be fine with that size of trailer.
So you tow 8000lbs with a 1/2 ton?
Yes. Well within the weights for the truck I bought. But the 2015 GMC Sierra with the Max Trailer package is a different beast than a 1/2 ton a few years old. Tow rating is 10,800 and the cargo capacity is over 2K.
Would not have done this with an older 1/2 ton.
I just started towing (around 6k pounds) with a GMC max tow and love it. These things are beasts. As I stated earlier, these max tow packages are darn near equivalent to some 3/4 ton setups.
