solrac65's avatar
solrac65
which truck is best
I am buying a toy hauler which weighs 14,189 and my ford F-250 has a max fifth wheel capacity of 15,900. Is that enough wiggle room or do I need a different truck ,which truck would be better dodge,chevy , or stay with ford I dont want a dually if I don't have to. Please help
  • if the dry weight is 14,189lbs i would count on it being closer to 15 maybe even 16 with 30% on the pin you are getting close to gvw without passengers..you could do it, but if you have a brake failure it is nice to have two extra tires to stop that much weight...
    Toy Hauler, ok now add all your cargo and the toys you will be well over 18K. Now take 25% pin weight, 4,500#. Now do you think your 3500/350 single rear wheel will be fine?????
    I am sure some will say yes.
    The responsible people know a Dually is in order.
  • it just never ends,
    today I saw a guy with a 1 ton ford F 350 duelly
    he was pulling a toy hauler, triple axle trailer, had to be at least 40ft long.
    now get this, he had a med size boat attached behind the triple axle trailer.
    I bet that old Ford 6.0 was overloaded to the max with that load.
    I turned one way, he when the other, the last time I was him he was still moving. what a load, the old ford was low to the ground under the weight of that trailer.
    my friend has a 38 or 40 ft toy hauler, triple axle and he pulls it with a 450 ford, 7.3 diesel with western type flat bed. he said the trailer is a load.
    I have no idea what a trailer like that weighs!!!!!!!!!!!
    would not want to hook my old Dodge 2500 to it.
    bet it would try to put it for a while,
