arkansasrunner's avatar
Jan 28, 2014
Which Truck would you tow with ?
I'm having a problem deciding which truck to use tolling my 5th wheel. I have a '94 Ford F250 4 x 4 7.3 Diesel 5 speed. (180 hp, Torque 338 ) I also have a '96 Chevy Crew Cab 3500 4 x 4 5.7 gas engine 5 speed. ( 255 hp torque 330 ) I know that I may be over weight on the ford a little bit. ( I think ) Our 5th is rated at 11,000 GVWR. Just want to use the saftest truck possible. Any response will be greatly appreciated. Thanks
  • Why not do what was suggested in your other post......LINK
    GO weigh the truck(s) so you know what you can tow......simple.
  • Does your 7.3 have a turbo. If so, no question go with the Ford.
    Even non-turbo it is a stronger engine and will be under less strain, you just won't go real fast.
