Sjm9911
Dec 21, 2020Explorer
Ok, so , i cook a bit. You will have a small inadequate kitchen in a camper. The stoves are low pressure, i have yet to see one with a good flame. In fact when the ac is on the flame is worse. Lol. Oven is almost the same, but workable. Best bet is to have a good outdoor set up. Good propane grill, griddle and burner. Also invest in a set of aluminum pots that nest. A few good knives, and forget the set of mixing bowles. Well maybe one that serves as a mixing bowl and mesering bowl/ strainer. You can keep the cast iron pan , i bring 2 of them. You will learn to adapt. Dont rip out the microwave just yet. I never use mine at home, ok popcorn only. But in the TT i use it a lot. Make meals and freeze them, pop in the microwave and dinner is ready. Now you can cook at home. I have also transitioned to paper plates for clean up. Sometimes the water conservation is hard! I would figure most of the TT have simmiler kitchens and storage capabilities. You learn to make due with less. Use stones in the oven for even heat. Grill more, cook on the stovetop less. Have fun and good luck with the search.
