3 tons wrote:
As I stated, wet baths do work out fine, but to some its not just about real estate...Dry baths are found only in the larger floor plans with slides FOR A REASON - the space is available
The OP is likely not talking about the typical 9-6" (< >) non-slide camper...If you look at the larger floor plans with a dry bath and slides you might even think that you're in a 5th wheel!!
Before making statements like the one above I put in bold you might want to take a look at some more campers. The NL 10 2 RR model has a dry bath and is a non slide unit. Then the one the OP is looking at is an Adventure 116DB. Now I would call this a larger camper with 2 slides king size bed and lo and behold it has a wet bath in it.
Just my opinion but it would be a pretty dull world if everybody wanted to have the same thing as you. But obviously there are people that want the WB models. The AF 990 9' 10" with a full wall slide has a WB and it is the biggest selling unit for Northwood. They make more 990s than any other model per Northwood.
