- jimh406Explorer III
Capt. Caper wrote:
Much better then my 01 02 F350 with airbags,rancho's.. Ford did majoy upgrades in 08 that made the difference.
Just to expand on this, the first Ford major upgrade was '05 which also included the coil front springs. If you are considering a SRW to haul a camper, the newer SRWs are almost always going to be better than a several year old truck.
BTW, all of the manufacturers have made upgrades. In '06 the only realistic SRW choice for me and my heavy TC based on payload was a Ford. That's not the case any more.
Likewise, an older DRW isn't nearly as good as a newer one with respect to payload. There is actually some overlap with older DRWs nearly the same as newer SRW with the SRW coming out ahead in some comparisons to older DRWs if you strictly consider payload rating. Besides payload numbers, there are stronger frames on newer trucks, the transmissions, axles, tires, and brakes have been upgraded as well.
Luckily for us TC types, SRWs and DRWs are continuing to be improved with respect to payload. - BedlamModerator
mkirsch wrote:
Bedlam wrote:
This was coming from someone that has 1500 lb TC on a DRW. If my AF 811 was that light, I would not need to modify my F250 to carry that TC and tow my enclosed trailer either.
It's closer to 2000lbs loaded and ready to camp.
I also have up to 2000lbs of tongue weight.
My TV is 7500 lbs empty and 11,500 lbs hitched and loaded. The weight is distributed differently but my SRW is hauling 4000 lbs. - Capt__CaperExplorerWell I have my 855S Lance on a 2011 F350 6.7 Crew Cab SRW with no add on's except Timbrens..It carries it fine. Doesn't sway or whatever.
My tires are stock ContiTR's and they have been so good I am on my 3rd set. I've hit some bad potholes with the rig on and they've held. - jimh406Explorer III
mkirsch wrote:
Not any of the TCs mentioned earlier in this thread... ANY of those could be hauled with a DRW truck with ZERO modifications.
What do you do with the OEM wheels and tires after you've bought the 19.5's?
Any could be hauled on a srw without modifications.
I sold mine. - mkirschNomad II
I also have up to 2000lbs of tongue weight. - mkirschNomad II
JumboJet wrote:
Wrong - I have seen more than one DRW squatting from the loaded TC and required modifications. I have seen responses on this forum from DRW owners that have added anti-sway bars, 19.5" wheels, air bags, Stableloads, etc. etc.
Who throws away a perfectly good set of wheels and tires?
What do you do with the OEM wheels and tires after you've bought the 19.5's? - nycsteveExplorerI have a Lance 981 with one slide on a 2011 F350 4x4 gas. The Lance is 4k #s wet. Mods on truck, airbags, Superswaystops,Rancho 9000xls. Rig handles well. Dont want a dually. They dont do well on the beach, thats the big deal breaker for me. Plus they are less mauverable. Im happy with my SRW.
- Coastal_WandereExplorerI am running a 2011 F350 SRW with a Lance 992 (double slide). We bought a SRW because we beach camp and the singles seem to be a better choice in the soft sands we tend to be on in the mid atlantic region. We have air bags which i air up to about 40 pounds and we added a heavy duty rear stabilizer. Truck runs great and pulls the load well. We off road camp and have had no issues. I have put 70,000 miles on the truck and we are well into our fourth season of camping with it. I am running the stock wheels and Continental Tires. I just replaced them at 65,000 miles. I think i could of gotten another 5000 out of them but i did not want to push it. I still have the original front brakes on the truck but had to replace the rear brakes at 50,000.
- Big_RigExplorerHad the 08 811 on the 00 250 SRW. Upgraded to Ranchos, Helwig swaybar, Stableloads, Ride-Rites and E-rated tires and wheels. The truck hauled the camper ok, but I did have some white knuckle moments on some roads. Still have the 250 and it would probably be still hauling the camper if I wasn't able to get the dually for a steal.
- JumboJetExplorer
mkirsch wrote:
rbcamping wrote:
What up grades have you done or plan on doing?
The whole point of a dually is that you can answer this question by saying, "NONE!"
You get a truck out of the box that's perfectly capable of hauling all of the aforementioned campers. No muss. No fuss. No suspension gizmos/doodads/gadgets. No throwing away a perfectly good set of brand new tires and rims.
It's just food for thought. Most of the "cons" to a dually are in your head.
I see you list a "2011 PJ 8x20 7-ton deckover equipment trailer".
Bring your DRW on down and load it up like this (notice the level SRW). That is a Case 580C BTW.
44,066 PostsLatest Activity: May 16, 2026
