mkirsch's avatar
mkirsch
Nomad II
Jul 20, 2015
Who makes custom ball mounts / shanks / stingers?
About 50% of the time I'm towing with the TC on, I have 7 ton deckover equipment trailer hitched to the truck.
I've been using a standard-length ball mount in my Reese Titan 2-1/2" receiver for the equipment trailer, but it is a little close for comfort. There isn't a lot of clearance under the TC overhang, and I can't turn very short or I'll hit a jack on the tongue of the trailer.
If I could just get a ball mount that was 4-6" longer between the cross pin and the ball center, I'd have plenty of room. Even 2" would make a world of difference. But, nobody makes anything like with the capacity I need (1400lb tongue, 14000lb trailer).
Does anyone know of a company that would manufacture a custom ball mount?
2-1/2" square, preferably solid bar stock
1" rise
1400lb tongue
14000lb trailer
1-1/4" ball hole
14" from center of cross pin hole to center of ball hole
A local professional welder might be willing to take this on but if someone out there specialized in this, I'd be willing to send the business their way.
  • There is probably a reason they are not made, too long too much tongue weight
  • There is no "off the shelf" extension for what I want to do.
  • Since there is a huge price in rigging for a "custom" anything, you would likely be far better off to buy an off the shelf extension and have it cut down to the length you need.
