RoyB
Jul 25, 2013Explorer III
Type in "30 amp electric cord" into google search and select images when it loads up. Pick your poison from the photos.
I use ETRAILER.com for all my trailer info needed. Most all the RV parts places will carry a replacement for your complete cable. LOWES and WALMART will most likely carry the replacement ends only if you just want to change that out.
Being loose has probably already damaged (burned) the contacts on both sides of the connection point. Be sure to look for burned contacts. You may have to replace the socket on the trailer now as well...
I order everything from AMAZON if I can come up with a part number...
Roy Ken
Roy Ken
