Chuck_S
Jul 25, 2013Explorer
Turn the power OFF at the pole before connecting to the trailer to avoid damage as shown in the photos. The water heater is typically turned on and you'll get a 15+ amp spark at the plug.
Replacing the whole cord is not necessary. The Roo trailer connector is a standard marine (read expensive) 30a 110v AV twist lock connector available at boat sources; the shore end is a standard 30a "RV" connector you can buy at Home Depot for probably under 10 bucks. This is 110v 30a, not 230v. Different than a dryer plug for example. Read the labels on the connectors or you'll get the wrong plug.
-- Chuck
-- Chuck
44,071 PostsLatest Activity: Sep 17, 2026
