camperdave
Oct 09, 2013Explorer
wrvond wrote:
The tools are not intended to be used under pressure. They are simply a safety item to keep your hands out of harm's way. If you are having to exert effort to lift the WD/AS bars or chain hooks into position or release them, then you either have too much tension on the bars, or the hitch head is too low.
Remember, too much tension on the WD bars is just as bad (or worse) than not enough. If your bars are rated too high for the job, they will result in a much harsher ride.
Are you saying that with the trailer hitched up and the tongue jack up, that the bars should just slip onto the L brackets? that makes no sense at all. If it required no pressure to lift the bars on, then they would not be doing anything once up there.
44,066 PostsLatest Activity: Oct 04, 2013
