jimh425 wrote:
If you can run the other three wouldn't it be jack specific? Is there a reset on the outside on the jack?
On Rieco's and CrappiJacks, each motor has a fuse on the controller itself, usually a 20 or 25amp. I have CrappiJacks.
To solve it...
My thought here is to move the fuse to the outside jumper wire where the wire exits the wall and goes into the motor, then put a wire jumper inside the controller where the fuses are currently. Doesn't matter where the fuse is in the motor circuit, so long as it's fused.
Of course, I won't know it's the fuse till I get the camper off the truck. Might be the relay on the board for that leg.
