amandasgramma wrote:
and to think, not that many years ago, NONE of them had power. :)
Ya, but they didn't weigh 6500lbs either......
So here's a visual of the problem---
Both Crappijack and Rieco put fuses
INSIDE the controller.
So, since the controller is mounted in the (not)access panel at the front bulkhead, my only to choices to fix this are--
1--Relocate the controller to the rear access panel, which would involve running all new wiring to the jacks.
2--Put a jumper wire inside the controller, basically bypassing the fuse there, and add fuses to the wires at the motor on each corner.
