valhalla360 wrote:
JRscooby wrote:
No matter how the weight compares to the rating, for a given weight, all other things equal, a higher numerical rear end ratio will put less strain on the rear end housing, the rest of drive line, and the part of the frame that joins engine to rearend. This is the reason the manufacturers change the ratio when they change the rating.
Sure, a higher load will add more stress but...
C
Same here...as long as you are within ratings, the extra strain has negligible effect on the drive-train.
As long as the drive train has the correct gearing.
A 2"x4", a human arm or a gear can all handle a certain load.
However as that load increases you may need to upgrade to a 2"x6",
a bigger arm, or a stronger gear. They all have limits.
What often lost in the comprehension is that the limit is determined by the weakest link.
