4X4Dodger wrote:
marcsbigfoot20b27 wrote:
3oaks wrote:
Yea, doesn't everyone know nothing less than a 350 dully is safe to tow anything. :R
Towing over 6000 lbs is a matter of.....
1/2 ton = good
3/4 ton = better
1 ton dually = best
Tow the same trailer with a 1 ton dually and get back to us.
F450 even better,
F650 even better
A 10 wheeled 35000lb over the road Freightliner would be even better. but NOT needed.
If folks are scared to tow a little over 6000lb with a F150. I would suggest a Freightliner. No sway, good braking, won't be pushed around by the TT. You won't even know it is there. Try it, and get back to us
1/2 ton, 3/4 ton and 1 ton are the normal trucks you see on the road. Your reply is trollish.
I beg to differ..the reply is NOT Trollish. It simply points out your very faulty logic.
Better is not necessarily the same as Bigger. There are many other considerations.
Towing with a semi isn't a totally trollish statement?
GFY
If GFY means what I think it does then your vocabulary is on a par with your Logic. (Both bad)
It makes one wonder why someone would take this so very personally as you do to write that over this issue?
I take driving and towing a heavy TT seriously/"personally". I don't want a 1/2 ton that is just 100 lbs under max weight to rear end me because itt can't stop going down a big mountain, lose control when a semi passes it and it swerves across the median causing a head on or just crashes in a ditch killing themselves.
If people here have never towed with more than a 1/2 ton then they don't have any experience to post any meaningful info about the differences with 3/4 or 1 ton.
