Vintage465
Jan 16, 2022Nomad
Gdetrailer wrote:Lantley wrote:
I can easily go a week with my propane fridge. With a baic factory RV set up with 2-12 volt batteries. No solar , no inverter, no sun requied just stock lp fridge.
From a simplicity standpoint "carringb" is spot on.
a 12 volt compressor fridge has advantages if there is a engine and travel involved. However if just sitting stationary a LP fridge is a simple versatile solution.
I understand solar is the wave of the future. A modern solar set up can do the impossible now days.
However if you just want to run the fridge off the grid without a lot of aftermarket investment/stuff, LP is still the simple solution.
Well until you factor in dragging a bunch of propane cylinders around with you.. They do get heavy to carry, even "20 lb" weight just under 40 lbs when full..
Most off grid homes and cabins now days employ a few solar panels a couple of batteries and a electric fridge and they run those for yrs without gens or refilling tanks. Dragging a bunch of heavy propane cylinders out into the bush is so 1800's in thinking..
I would rather have a electric fridge with solar and battery than drive an battery powered vehicle.. I have plenty of time to camp and wait for batteries to recharge via solar than wait for half hr or more in a parking lot to get a 20% charge for a vehicle just to get to the next power station.
You're way off base with the phrase of dragging bunch of propane cylinders. I go a month using the water heater and the fridge, cooking etc...............using two 7-1/2 gallon tanks. But my question is. Why do people think it's the hot ticket for boon docking? I can see if you're regularly driving and covering ground.
44,071 PostsLatest Activity: Aug 16, 2026
