Huntindog
Dec 25, 2022Explorer
bironacad wrote:I just looked up the Furrion 12V, 8CF fridge.
Just purchased a Grand Design TT with a DC fridge. The fridge is 8 cubic feet and It cools down very fast compared to an absorption fridge and you can run it while on the road. The antenna booster draws 1amp while on, the fridge 3. The trailer does come with a 165 watt solar panel. I like the fridge capacity size increase. Thinking of adding another panel and upgrading battery to lithium to run an inverter for AC when required while off grid. I think both have advantages. I started with a pop up, then went with a 28’ fifth wheel, then a 40’ Red Wood, drop down to a hybrid and now have the 200 mk trandscend. Lol heading to Yukon this August and will know much more after that trip. Lol enjoy what you have! And don’t stand with the door open. Play safe.
High efficiency DC compressor
Input voltage: DC 12V (min. DC 10.5V to max. DC 17V)
Input power rating: = 15A (11A @ 12V DC)
Energy Consumption: 1.08kWh per day.
You will need a LOT more solar as well to feed the batteries.
Basically you will have a math problem. one 100AH Lithium battery will be drained everyday by the fridge alone.
Solar averages about 60% of rated output.
You can do the math however you like. I see you comming up way short.
44,071 PostsLatest Activity: Aug 16, 2026
