dsrace
Jan 14, 2023Explorer II
the simply answer to the op's question is, personal application. the end users wants are what it all comes down to. some have no issues with the functionality of a conventional lp/electric rv fridge where others want the functionality of a conventional compressor fridge.
i opted for the dometic 12 v dmc4101 in our current camper. i have never had any great experiences with lp/elect rv fridges four our use in the last 5 rv's over the last 20 some years. never had one fail but on hot days they struggle to get the job done. when i say that i mean, one can leave a can of soda in the freezer overnight w/o fear of it bursting.
i ran across some test results conducted by mike at rv travel. they were the deciding factor to go with the dometic dcm 4101 and in particularly because it has 3 different power level settings where most of the other brands do not. not saying it is better or worse then other brands just saying it meets my wants better then the other brands. here is a link to that article and a pic of his test results on a single 100 ah battery. i only have 200 watts of solar and a 200 ah renogy agm battery.
https://www.rvtravel.com/rv-electricity-jam-dometic-power-usage-part-1/
if one was only opening the fridge 2 to 3 times a day then one could leave it in eco mode with only a 3.5 amp draw, when it cycled. it does not run for an hr every time it cycles either.
44,071 PostsLatest Activity: Aug 16, 2026
