StirCrazy
Jan 15, 2023Moderator
haha ya I know its only 5000 to have a 480 watt system installed from the stealership.. same set up would cost about 500 if you did it yourself.
are you sure all the watt hours are coming from your panel and not some from your generator, 400wh is about 33Ah which is above the practical maximum output for a 12V 100 watt panel but who knows not all panels are the same and you might be in a place that give you perfect solar all day or a movable mount so many factors.
I tried testing my set up to see if I could run the outside kitchen fridge on the invertwe while I was camping.. I can for about 2 days then I am down to 50% and time to shut off the inverter. thats with 480 watts of panels and 4 210AH 6V batteries. I do plan on upgrading to about 1000 watts of panels and 900AH of LFP batteries in the 5th so maybe I'll be able to do it then.
