dsrace
Jan 16, 2023Explorer II
Huntindog wrote:
My Coach has an 18CF fridge. I have yet to see a 12V fridge that big. I have looked at the specs on some 8CF ones. They are remarkably similar in specs. All of them would drain a 100 AH Battle Born battery every day. So I am pretty sure an 18CF 12V would need two 100 AH batteries each day. To keep my current amount of headroom for bad events, I would need to add 3 Battle Born 100AH batteries. Then I would need to add enough solar to feed them. That is not happening. Not enough room on the roof, and my Solar controllers are maxed out.
I am not interested in going on a electricity consumption diet.
I will keep my gas fridge, thank you very much
With out a doubt, 12 volt comp fridges do not fit everyone's needs. All of my sand dune trip are at parks that have either full hook up or a min of water and electricity. Based on real world trial and the specs in my previous post, our 10 cu ft domestic 12v will easily run 24 hrs on battery only. Im only using 1 200 ah renogy agm. If I were boondocks long term, then the fridge would require a gen or more solar then my current 200 watt system. 200 watts is more of a battery maintainer then a charging system, imo. I thought I saw domestic offered a 13 cu ft 12v but not 100 % on that. I have had 6 campers and 5 of them had absorption fridges. None of those fridges perform like our current domestic 12v as listed in previous post. For our application, I wouldn't willingly go back to an absorption fridge.
This 12v is food safe in 4hrs after start up. Much better for our application as I don't have to turn it on 24 to 48 hrs before. Only the 2 of us and a 10 cu ft is massive over kill. On a 7 day trip we didn't completely fill an 8 cu ft. I doubt the 8 cu ft is any diff on power consumption.
