Gdetrailer wrote:
ktmrfs wrote:
Gdetrailer wrote:
Your camping in a RV, right?
Your RV NEEDs a 12V battery for basic functions like powering the control board in your propane fridge, right?
Your battery charge does not last a month, right?
You must recharge the battery periodically anyways, right?
Since you obviously must recharge the RV battery, you must have solar, gen and or a huge battery bank to last more than a long weekend, right?
So, where is the "advantage" of a propane fridge if you already have a battery, must have a gen and or solar and recharge the battery daily or every couple of days?
advantage of a propane fridge is I can go 4-6 days before i need to recharge even with no solar or generator. No way could I go for that long with a 12V compressor fridge. If the sun is out much at all I can keep the batteries fully charged easily. With a compressor fridge, nope, I'd still be bringing out the generator even with full sun every few days.
Propane advantage over batteries is propane energy content/gallon or energy content/lb is orders of magnitude higher than a battery. Now I will agree that a compressor fridge cools down faster and is less temperature sensitive than a propane fridge. So if you camp with power handy it makes sense.
With LED lighting & propane fridge in nice weather battery draw is pretty low. Even in cold weather we still can go several days in cloudy weather before needing to dig out the generator.
So if we had a compressor fridge when we boondock for 2 weeks I'd need to bring along more gas for the generator. As it is I seldom even use all the gas in the generator, still have lots of propane left. For us have no desire to have a compressor fridge for the type of "off grid" camping we do. If most/all our camping was at places with available 120V, then a compressor fridge would likely be high on the list.
Your forgetting the mere fact that unless you have a very, very small (2 cu ft or smaller) propane fridge which doesn't need 12V for the control board your RV fridge is using battery 24/7 and when it opens the gas valve, the gas valve consumes additional battery..
I can go 24 hrs on one single pair of 6V GC2s (215 Ahr) and use less than half of that capacity. GC2s life cycles are based on using 80% of the capacity which means I can go as long as 1.5 days.
If I added an extra pair of GC2s I have the capability of 3 days with no charging.
If I added about 200W-300W of solar and had two pairs of GC2s I would be right at 6 days without the need for a gen.
Now, to add some insult to injury to the idea that propane is "superior" I am doing this with a 120V home fridge with a inverter.
12V fridge compressors tend to be a bit more energy efficient which means 200W of solar and 4 GC2s would give you easily 7-8 days without the need for a gen. If I remember correctly 12V compressor fridges tend to only use about 25 Ahr per day which is only twice what a propane fridge with electronic control board.
Granted, with my inverter I cheat a bit, it has a "power save" feature which turns the inverter on/off. When the fridge T stat calls for the compressor the inverter snaps back to life powering the fridge, when compressor shuts off, the inverter goes back to sleep. That in it's self saves me a good 24 Ahr of battery per 24 hrs.
You may as well get used to the idea that propane fridges are slowly being dropped. Given the fact that compressor fridges over the yrs have become very energy efficient, battery capacities and solar are improving and the cost to build compressor based fridges are much lower. It really will not take much to adapt to a 12V or even a120V compressor fridge.
You might wish to consider that propane costs have increased greatly, they are not going to get cheaper and with the all out attempts to banish everything that operates from any fossil fuel sources (propane is carbon fraction extracted from crude oils and natural gas via refining processes) it too will be in the cross hairs of extinction..
with the larger propane fridge in my 5th wheel 7cu ft, with 4 GC batteries I can go just shy of 2 weeks with out charging, and my fridge has fans to move air across the fins in the back. if I am not runing the inverter for other stuff or the furnace. so I don't realy concider 3 days that great, in fct I would be down right upset as that is 33 ah a dayassuming your only using 1/2 the capacity of your batteries and the adverage battery is around that 200ah mark. now add fringe season to that where your going to run your furnace. yes the fridge might drop off as it isnt starting up as much so say it drops to 25 AH a day, add in the furnace and your talking big draws..
my truck camper only has a 5cuft fridge but it has two GC2 208AH batteries and 325 watts of solar. the adsorbation fridge makes it so the furnace is the major draw and I can camp indefinatly in that if there is sun every two days. if I had an 12V fridge I would probably make it a weekend but beyond that would be dicy
for me I think if you always camp where its above 75 degrees so you never run the furnace then ya a 12V fridge makes sence and you can compensate for it, or if you just run the furnace for a fe min to take the edge off in the morning type thing. this way you have a workable load and solar can cover it. you start adding the full time furnace into it and maybe other loads that are even more (inverter microwave, coffee pot etc) then your needeing even more batteries and larger solar and hoping you don't have many cloudy days. I do like some aspects of the 12V fridge , but you can make an adsorption fridge preform just as good and use a fraction of the power. for people that mostly plug in then adsorption fridges are awsome, just need enough power to get where your going. I am seeing the adsorption fridges more in the larger pull to a park and stay there for a month with hookups type units.
don't forget large battery banks and solar are not the normal, it seams like it on here but you go out camping and its amazing how rare it is to see that kind of thing. mind you I would expect to see more of it down in the hot areas of the US , but even then gennys might be more popular.
Steve
