ShinerBock
Oct 20, 2020Explorer
Why diesels are most efficient around 1,800 rpm
Finally got more of an answer to why all diesels are most efficient around 1,800 rpm. In comparison to what I thought, it has more to do with how diesel burns than other things like compression ratio, bore/stroke ratio, and turbo map efficiencies. While those are still a factor in how wide/narrow the window of efficiency is around 1,800 rpm and how efficient it is, the fuel burn rate of diesel fuel itself plays a bigger role as to why all diesels are most efficient around 1,800 rpm.
"The answer to your question involves fuel chemistry, engine geometry and thermodynamics. You can look at the power, torque and fuel consumption graphs for a wide variety of consumer turbocharged (and most non-turbo) diesels going back decades, and you’ll see a common theme in the data. Whether you’re driving a new Chevy Cruze or a Dodge ¾-ton pickup equipped with a 6.7L Cummins, all produce the best fuel economy near to 1,800 rpm, and all produce the maximum engine torque somewhere near to 1,800 rpm.
A big factor in the magic of 1,800 rpm is the volatility/combustibility of diesel fuel and how it affects flame propagation during the combustion process. Diesel fuel, even when finely atomized, doesn’t combust as quickly as gasoline. It takes time for the fuel charge inside the cylinder to completely burn. As it turns out, the burn time during combustion is nearly ideal with an engine turning 1,800 rpm. This longer burn time is partly why diesel engines produce more torque than a gas engine—diesel combustion results in more push on the piston over a longer period of time. To take advantage of this longer burn time, modern diesel engines can have a bore/stroke ratio that’s square or under square, meaning a diesel engine generally has a longer stroke than piston diameter. On the other hand, gas engines generally have an over-square piston/stroke geometry (larger piston diameter than stroke) because of the higher volatility of gasoline.
Knowing all this, manufacturers of diesel engines, turbochargers, fuel injection systems and engine control systems have all directed their efforts at producing engines that make the most of this 1,800-rpm phenomenon. So, drive your diesel at or near to 1,800 rpm if you’re looking for the very best in both engine torque and fuel economy."
