towpro's avatar
towpro
Why do I need a DC to DC charger?
I came to this group because of the tendency for truck campers to be more off grid oriented with knowledge about coach batteries.
Unless your using Lithium, why would you need a DC to DC charger between truck and coach? I know there will be some loss in the factory wiring (which gets smaller every year) but do I really need to limit current or voltage?
On my Ram it was not switched, and I knew to unplug the cord when camping to not discharge the truck batteries. Is the DC to DC charger only to prevent the truck battery discharge?
I was tempted to put a bluesea ACR on this line but they will conduct either direct either directions at a given voltage, IE my Camper solar would start to charge truck batteries which I don't need.
Really this question comes from I am wiring a new Toad. My Jeep Liberty I have the 12V feed wire from RV connected (fused) direct to the battery. Now I am wiring a new toad, a Ford C-max and I am reading about everyone using these special DC to DC chargers. But why do I need it? The truck alternator is only going to put out a max voltage, by the time it goes through the thin wire to the toad, its going to be even lower, so why do I need to regulated it?
  • Kayteg1 wrote:
    theoldwizard1 wrote:
    YOU ABSOLUTELY DO NEED A DC-DC CHARGER !!
    Now I wonder how could I survive 34 years of RVing without one? :S
    Because vehicle "smart charging" system did not show up until after 2001 ! (Said the guy who actually wrote some of the software before retiring !)
    If you just want your house batteries to not run down (further than they are), you don't need one.
  • BB_TX wrote:
    Curiosity leads to google. And there I found this;
    A DC-DC charger is effectively a smart-charger for your 12V system. It isolates the house battery system from the alternator, so that the vehicle's computer management system sees it as something like a set of lights.
    You are partially correct ! A DC-DC charger actually BOOST the voltage that is being applied to the house battery bank to a proper multi-step "smart" charge.
  • towpro wrote:
    ...why would you need a DC to DC charger between truck and coach?
    Kayteg1 wrote:
    You don't.
    On vehicles with smart charging system that gets complicated, but to my knowledge no US build truck to date has such system.
    Prove it to yourself. Start your truck. Check the voltage at the battery. Immediately after starting it should >13.8V. Let the truck idle for about 10 minutes and check the voltage again. Probably <13.2V ! Have some one hold the engine at a high idle. I'll bet it is still <13.4 !
    13.2V - 13.4V at your house battery bank will not let it discharge but it will NOT re-charge the house battery bank !
  • You don't.
    If your truck doesn't have charging circuit switched off, check if your camper has build-in battery separator.
    If not, battery separators sell for like $50 on ebay.
    So unless you have batteries with higher voltage, or drive Mercedes with smart charging, the B2B charger is just dead weight.
  • Curiosity leads to google. And there I found this;
