Arizona_Kid
Oct 07, 2013Explorer
mileshuff wrote:
I've never had an issue with a water heater in any of my trailers. The only areas we RV are in AZ and southern CA, both with very hard water. My last trailer was 10 years old when I sold it. Heater still worked great. If its not hard water causing the problem then what is?
Did you have a hot water heater that uses an anode rod? Atwoods do not need one. The anode rod saves the water heater, so if you have a Suburban water heater I would check the anode rod, you may be living on borrowed time, as maybe was the 10 year old one you sold.
44,056 PostsLatest Activity: Jun 25, 2013
