tunkcurt1
Jun 19, 2015Explorer
You definitely want to laminate the luan to the FRP prior to mounting. That is the only way to ensure you will get a good bond between those materials. If you don't get a good bond, you run the risk of delamination.
Azdel is a great alternative, but you will not get the same rigidity that you would with the luan so you might have to make that up with the mounting structure. It is also quite a bit more expensive.
Make sure you get FRP that is designed for outdoor use.
44,068 PostsLatest Activity: Apr 17, 2021
