- Old-BiscuitExplorer III
mmyoyo wrote:
Model # DM 2652
That model goes into limp mode upon failure of thermistor.
Limp Mode on that model means 'continuous cooling' on the heat source selected.
It will run continuously until sensing restored....thermistor placed back in clip on fin (if it has fallen out/hanging down) OR replaced. - mmyoyoExplorerModel # DM 2652
- camper1013ExplorerI had this problem this summer no matter where the slider was. After I pulled stuff out of the fridge to check the thermister as advised, I found that the sensor fell out of the plastic slider clip and was hanging in the bottom of the fridge. Once I clipped it back on it seemed to work.
One other thing to make sure you check. - Old-BiscuitExplorer IIIChanging position of thermistor (UP/DOWN) applies to the fridges that use 'Auto Temp Control' ....no temp setting adjustments on upper panel,,,,and have a Decal on fridge sidewall showing Cooler/Warmer settings
Otherwise ...leave thermistor in OEM position which is where the thermostat is calibrated for the different temp settings
Items freezing in Food compartment......thermistor is BAD,\ replace it
Posting Model when asking for help is advisable - 2edgeswordExplorerWhat is the model number? Usually there is a switch on the outside of the frig which along with positioning the thermistor on the inside fins controls the temperature.
