Harvard wrote:
DownTheAvenue wrote:
Harvard wrote:
If the RV is sitting on front and rear blocking AND has vinyl floors, there is the risk of flexing the cold vinyl which will crack in the process. The flexing is caused by the tires changing their load bearing with temperature changes. Just leave the RV sit on its wheels and front jack. Been there, done that...
For this to be possible, the tires would have to expand and contract significantly, even visibly, while the the front and rear "blocking", presumably the stabilizer jacks, would remain constant regardless of the varying temperatures. If the floor warped enough to crack the floor covering, the siding and roofing would have gaps enough to put your hand through!
The way I see it if the tires were about 50PSI at 70F in the summer they would drop to about 40 PSI at -10F in the winter. With both ends up on blocks the tires would be supporting less weight in the winter then they did in the summer. I may not have the science down pat but I do believe in the cause and effect aspect of this experience.
You are exactly correct. The tire pressure will vary slightly summer over winter, and your estimation of the pressures may be accurate. The question is how much will the lower air pressure cause the trailer to lower. Very, very little. I bet not enough to even cause an exterior door to jam. Certainly not enough to cause the interior floor to buckle so much that the floor covering rips apart!
In extending the stabilizer jacks, you can often watch, especially at the back, the trailer actually rise as you tighten the jacks. That is more rise than you would experience in the scenario you have envisioned.
Your floor covering cracked due to the extreme cold you experience in the Winter. After all, living North of Calgary gets pretty darn cold! By the way, nice house!
