adamis's avatar
adamis
Nomad II
Aug 29, 2022
Why shouldn't I go this route? (AC Roof Delete)
In my previous post I discussed a basic plan of upgrades I have been contemplating for my camper. One of those included removing the roof top AC unit altogether and going with a Truma Air Combo Heater / AC unit like this.
Edit: Just found this as the Truma Air is only for European markets. This looks to be for US markets.
It is a AC / Heater unit designed to fit under a bed or in my case the dinette seating in place of the current furnace. Granted, this is for the European market so it is setup for 240v but that is fust a flip of a switch on an inverter so not a big deal in my opinion.
I recently connected with a boat repair shop and we discussed some future projects on the exterior of the camper to include removing the rear awning (never used and weathered anyway). Removing an older rigid solar panel on the roof held on by screws and sealing screw holes. Removing radio antenna from roof. Removing AC unit from roof and deleting opening entirely and finally, possibly removing the railing on the rear of the roof camper and sealing all of those holes.
All of this is in preparation of resealing the entire roof and then laying down as much solar as we can. 400w should be easy but 600w or more are probably also doable using custom solar panels (flexible time held down with eternabond tape). The goal in this is to eliminate as many screw holes and openings on the roof and open up as much space as possible for solar.
Getting back to the AC unit. I've been contemplating going with this Truma Air Saphire unit that can be installed under the dinette where the current furnace is. I can reuse all of the ducting as well making installation a breeze.
These are all pretty big upgrades but the end goal is to have a sealed roof with as little penetrations as necessary and a new AC unit that can be run off of the solar and batteries.
Does anyone have any experience with something similar? Or, does anyone know of something similar to the Truma Air that is an alternative?
