CavemanCharlie
May 09, 2015Explorer III
VentureVan wrote:
Our trailer box is only 14 ft. long but I can see how trailers that are in the upper 20's or over 30 ft. could easily drag the back end on the pavement over even regular driveway inclines because of so much rear overhang. Maybe coil springs and airbags, that way you could raise the trailer when clearance was needed then lower it for cruising on the highway. :)
Humm,, You know , my 1984 Lincoln has a air spring at each corner. No coil springs at all. I've seen videos of people that use this type of system to lower the car for show and then raise it up to drive. I suppose something like this could be added to TT. Not sure why you would want to but, it could be done.
44,068 PostsLatest Activity: Apr 17, 2021
