Good info all around! I read the links and thanks to 2edgesword I can check the dates on my tires.
After reading the links provided and the posts so far, I am leaning heavily towards LT tires when I need to buy new ones. Don't mind getting new wheels, bigger tires, as the axles are already flipped so plenty of room for bigger tires and a little bit more ground clearance from taller tires would be welcomed.
And it's not so much that I'm going to be in that much of a hurry, just that a lot of the interstate around here is posted 80 MPH and the de facto speed limit is 85 MPH. Doing 65, a full 20 MPH less than everyone else on the road, even in the right lane, makes you kind of a hazzard to the other drivers. I'd like to be able to do 75 MPH and not have tires be a concern. Plus, like I said, for how I'll mostly be using the TT, a little more ground clearance would be nice. Plan on welding up some skid plate for the exposed drain pipes before taking it anywhere as is.
- Coyote
