ktmrfs wrote:
So again, anyone with a TPMS have a blowout?? Has it warned you of a tire loosing pressure?
I did.
I have a TPMS that monitors temperature and pressure. The small-pressure loss threshold was set to about 3psi.
About 6 years ago, I was driving at 55-60mph on a state highway when there was a loud bang and the "sudden large pressure drop" warning started screaming.
There was no pre-warning of a 3psi drop or a spike in the temperature.
The tire had completely disintegrated. Fortunately no significant damage to trailer other than the skirt on the trailer was slighly bent outward.
I later upgraded to Denman tires with a higher load range (D) and all has been well so far. Unfortunately Denman appears to be out of business and based on the current tires being 6 years old, I will probably buy new tires next year. Not sure what I will get, porobably Maxxis. I would get LT but they are 15" and there are no similar load capacity LTs that fit in my wheel wells.
I suspect that LTs that fit might handle the same load as the STs but since LTs are used on occupied motor vehicles they are much more conservatively rated. I just don't see how a cheaper tire (ST) would really be able to handle a higher load than a more expensive tire (LT). It seems that it would take some special materials and fab techniques to allow a tire to carry extra load, and this would cost more not less. Just my opinion.
Steve
