UTCoyote
Jul 05, 2013Explorer
Why ST tires?
Hey All, Total noob, trying to soak all this RV stuff in all at once. The Maxxis ST tires on my recently purchased 2001 TT "look" like new, but I don't know how old they actually are, so don't kno...
JJBIRISH wrote:JIMNLIN wrote:
The rules are pretty simple, the replacement tires must equal or better the tires listed on the vehicles tire placard…
JJ, knows as well as most folks that the tire placard is a recommendation only. When you use the word "Rules" it implies some kind of law. There is no enforcement law that says the replacement tires have to be the same type listed on the placard.
The only enforceable law is roadside. They look for a DOT number and the tire capacity to match the vehicles axle ratings.
if your trailer came with ST225x75x15 in LR D @ 2540 lbs. capacity on the placard you can’t just say you can use a Wrangler HT in LT215x15 LR D @2090 lbs. capacity or in a LT 235x75x15 LR C @ 1980 lbs. capacity, which is what is often recommended in the forums for this situation…
Incorrect.
What I and others have recommended and are actually using is those two 1980-2080 lbs capacity LTs you mention for replacing a ST205/75-15 C at 1820 lbs capacity.
Actually you are incorrect, I know you insist this is not true and have posted so even for my state…
“Jack, you and FastEagle are playing to the tire placard liability thing simply by constantly bring up the issue just like your last post referring to certain tires that have been mentioned wouldn't pass your state inspection. Baloney. FastEagle has tried that trick also.
As long as the tire has enough tread depth and enough load carrying capacity/etc it will pass anyones state safety inspection requirement or even pass the annual fed safety inspection required for a commercial trailer/all vehicles regardless of tire type.”
The PA inspection say… the mfg. that being the trailer mfg. as the one required to correctly placard the vehicle… there are other provisions in the law pertaining to the trailer tires condition and tread also, but I am not about to search them all out right now…
(g) Tires and Rims - The axles of a vehicle
specified under this subchapter shall be
equipped with the number and type of tires
and rims which have a load rating equal to
or higher than those offered by the
manufacturer.
If the placards are only recommendations why do they deserve to be safety recalled so often for having the wrong information on the placards…
There have been recommendations made on the forums based on claimed trailer weights only that have had nothing to do with the trailers placard weights or even the axle weights…
While I haven’t ever made the claim that the tire type must be the same and that is misquoting me, the inspection law does in fact say the same number and type and load rating equal to or higher than…
You consistently accuse myself and others of boxing the tire builders into a corner when they are asked for information only because it don’t agree with your personal positions…
One posters response
We do not recommend using light truck tires on trailers that specify ST tires. If the trailer manufacturer calls for ST tires, it is important to replace with ST tires in order to maintain the load requirement.
Thank you for choosing BFGoodrich.
Your reply
“The OP backed BFG into the liability corner with that type question. He will get the same answer from any LT or P tire maker by asking for a direct replacement for a ST tire.”
And
“If your really interested in using LT tires don't back the tire makers or their dealers into the liability corner. “
Obviously you don’t think these are big boys that know how to answer for themselves…
My e-mail reply from continental tire
Thank you for contacting Customer Relations at Continental Tire the Americas, LLC.
We no longer manufacture ST tires, and the Vanco line is not a suitable alternative.
We would recommend searching for a dedicated ST tire line.
And your reply
“You badgered Vanco with the more canned questions until they gave you the answer you were looking for”
None of these people according to you know how to answer normal questions to their help line… no badgering, no pushing… the answers just don’t back up your opinions...
If you want the answer you are looking for according to your words, be sure to softball your questions
If these companies can’t stand tall on their own feet and recommend a LT tire, no, their LT tire even one with sufficient load capacity as a replacement tire for a ST tire why should I or anyone else assume it’s the thing to do, or assume you and others are their secret information outlet…
And this coming from me someone that generally don’t like the ST tire or their specifications, or their DOT certification requirements, and have voiced this many times, and believe the LT tire is a better tire… someone that if not for the Maxxis brand having proven itself to me, would be faced with a serious personal dilemma….
