ShinerBock
Dec 05, 2019Explorer
Grit dog wrote:pianotuna wrote:
How many folks tow at 75 miles per hour? 55 would make more sense.
Me. (Depends what I'm towing and where)
Same here.
Although I thought we already had this convo before.
To summarize and generally speaking....
If you are in your 90s, towing over 25 mph is too fast.
If you are in your 80s, towing over 35 mph is too fast.
If you are in your 70s, towing over 45 mph is too fast.
If you are in your 60s, towing over 55 mph is too fast.
If you are in your 50s, towing over 65 mph is too fast.
If you are under 50,then you more than likely tow between 65 and 75 mph unless your are noob which in that case refer to the over 60 years old crowd.
