ford_truck_guy
Dec 05, 2019Nomad
Terryallan wrote:8.1 Van wrote:
Tesla semi towing
Tesla semi towing #2
Break it down some. A trailer truck with 240 gal fuel tanks can travel 1200 miles before stopping to fuel. Hmm that is what 3 times farther than the pictured truck can go. and can be refueled in 15 minutes. This is very important. most time when you load, and go. You have a time limit to deliver your load. get there late. You lose money. You really don't have time to stop and charge batteries three times compared to not stopping with diesel in the same 1200 miles, and the farther you go the more you have to stop. This is a time killing option.
Normal tractors weight in the 25000 to 30000lb range. leaving a payload of 50,000lbs, and for them weight is money.
How much does the electric truck weigh? Well we aren't told. But I would tend to believe it weighs considerably more than a normal tractor. just for fun, say weighs 40K. You have just cut your payload 10000 to 15000lbs. You just lose money. And you got there late.
The OTHER issue with the BIG RIG will be the NEW "ELD" Electronic Logging Device... The drivers have to factor inn the fact that they are "On Duty-Not driving" at each fill up.. They only have a certain amount of hours to work with.. Charging could eat into that pretty fast..
"This window is usually thought of as a “daily” limit even though it is not based on a 24-hour period. You are allowed a period of 14 consecutive hours in which to drive up to 11 hours after being off duty for 10 or more consecutive hours. The 14-consecutive-hour driving window begins when you start any kind of work."
