el_jefe1
Aug 22, 2018Explorer
myredracer wrote:
Curious if you might have a link to their requirements?
The RVIA sticker on the side of our trailers says "Manufacturer certifies compliance with standard for recreational vehicles NFPA 1192"
Specifically it fails in at least two areas:
6.2.1.2 Each sleeping area shall have two different paths to escape to the outside of the recreational vehicle.
6.2.5.1 Means of escape, if not an exterior passage door, shall provide an opening of sufficient size to permit the unobstructed passage, with its major axis parallel to the plane of the opening and horizontal at all time, of an ellipsoid generated by rotating about the minor axis an ellipse having a major axis of 24 in. (610 mm) and a minor axis of 17 in. (432 mm).
44,071 PostsLatest Activity: Aug 16, 2026
