ppine wrote:
There is a common theme on this forum. People wringing their hands about whether they have enough truck to pull their trailers.
There is a simple solution. Spend the money, step up and buy a truck like a 3/4 ton that is designed to pull with. A truck with sufficient torque, an 8 foot bed, a trans cooler and the right gears. Then life is simple when it comes to towing.
There are some better 1/2 ton trucks now, but I would never own a truck with a 5.5 foot bed or ev en a 6.5 foot bed.
I don't see anyone wringing their hands. They are simply asking questions about what is needed to do the job.
Just because a 3/4 ton is right for you, doesn't mean it is right for the rest of the world. For some people a 1/2 ton is just fine.
Funny how your simple solution is "Just Spend Money", might be pretty easy in your shoes. Others may need to work with ratings that cover their needs and put off having icing on their cupcake for another day.
OP, you can get accurate, unbiased (un-opinionated) information to work this through yourself here:
Clicky
