srockey's avatar
srockey
Will it pull my trailer?
I am looking for a new/used truck to pull my travel trailer. I have a Keystone Passport Ml199 that weights 3800 lbs empty. I would like to get decent gas mileage since it will be an every day driver. The truck I am looking at is a 2014 Chevy Silverado LT Double Cab 4x2, 6 cylinder. The specs sheet says 6,000 to 7,100 lbs, and I know those are over estimated. What do you think?
Thank you,
Steve
  • I think your truck will work in most conditions, with that size trailer. The higher horsepower, higher revving V6s do well coupled to the multi geared transmissions. Steep hills, high winds, just take your time. It will get you there.
    Jerry
  • I have a 2007 Chevrolet with a 5.3 V8. On the interstate I get about 22 mpg. If I hook my two wheel utility trailer to it...16-18 depending on the load. Pulling our 2009 Puma 25RS....it goes to about 11-13. 13 being on a good day.
  • “Pulling” isn’t the only number. What is the TV’s payload capacity?
    “I drive a 2004 V8 Toyota Tundra with the factory tow package.” This TV would probably have been better.
  • Should be OK in the FL flatlands. Once you hit the hills all bets are off.
