rjkfsmExplorerJan 03, 2014Will it sway?On a one time basis, I will be towing a 32' travel trailer. The trailer is totally empty and dry and weighs about 4,500 lbs. There will be about 200 lbs of cargo put inside near the front, so toungue ...Show More
Francesca_KnowlExplorerJan 03, 2014Keeping the speed down is important since most sway events occur at speeds above 50-55.IF the trailer has brakes and you can manually activate them to stop any unanticipated sway events, I think you'd be fine.
