rjkfsm
Jan 03, 2014Explorer
Will it sway?
On a one time basis, I will be towing a 32' travel trailer. The trailer is totally empty and dry and weighs about 4,500 lbs. There will be about 200 lbs of cargo put inside near the front, so toungue ...
Ivylog wrote:
The secret to no sway is plenty of tongue weight. You have plenty so do not worry about it swaying.---
coolbreeze01 wrote:If plenty of tongue weight could eliminate sway, there would be no market for sway controls.
As mentioned, enough tongue weight will eliminate sway. Good luck.
