rjkfsm
Jan 03, 2014Explorer
Will it sway?
On a one time basis, I will be towing a 32' travel trailer. The trailer is totally empty and dry and weighs about 4,500 lbs. There will be about 200 lbs of cargo put inside near the front, so toungue ...
rjkfsm wrote:
On a one time basis, I will be towing a 32' travel trailer. The trailer is totally empty and dry and weighs about 4,500 lbs. There will be about 200 lbs of cargo put inside near the front, so toungue weight should be around 600 lbs.
The truck is a 1/2 ton with a 8,600 lb tow rating. I have towed 4,000 lb trailers and cars with no problems at all even through the mountains. 400 lbs of cargo with a 300 lb toungue weight trailer made the truck sit level since unloaded it has a slight rake.
Since it is a one time tow, I don't want to invest in sway bars and such and I am planning on driving about 55-60 mph max. I know there are no absolutes, but opinions would be appreciated.
RK
