rjkfsm's avatar
rjkfsm
Will it sway?
On a one time basis, I will be towing a 32' travel trailer. The trailer is totally empty and dry and weighs about 4,500 lbs. There will be about 200 lbs of cargo put inside near the front, so toungue weight should be around 600 lbs.
The truck is a 1/2 ton with a 8,600 lb tow rating. I have towed 4,000 lb trailers and cars with no problems at all even through the mountains. 400 lbs of cargo with a 300 lb toungue weight trailer made the truck sit level since unloaded it has a slight rake.
Since it is a one time tow, I don't want to invest in sway bars and such and I am planning on driving about 55-60 mph max. I know there are no absolutes, but opinions would be appreciated.
RK
    If those weights are actual then 600 / 4500 is just over 13% which is good. If not towing too far and if you keep the speed to 50-55, avoid windy conditions, and slow down when 18 wheelers pass then you should be okay. Of course the truck has to maintain a level altitude, and the hitch and axles should be within rated capacity.
  • Guess maybe more info is needed like weather conditions, mountains or flat, road conditions such as snow, etc. If you're thinking in the Midwest or northeast in the next week, my suggestion would be not to even think about it with the weather and road conditions. Actually, wouldn't even think of towing anything right now under those conditions. If you're thinking drier roads, no strong winds, flatlands with no curvy roads, I'd ask if it's possible to borrow/rent a WDH. IMHO, all it takes is that one time. Good luck. Better safe than sorry.
  • If your hitch receiver is rated for the weight you're putting on it without a WDH, and you have a brake controller, I don't see why not.
