Michael_J_'s avatar
Michael_J_
Will my 2014 F250 need overloads?
I have a 2014 F250. I just bought a 1999 Northstar Laredo hard sided 8' slide in camper. I am still working on the camper so I have not been able to mount it on the truck yet. Therefore I do not know the combined weight of both for sure. I also have not been able to eyeball the camper on the truck and see how much sag I have. For my planning I was wondering if anyone can predict the future and tell me if I will need spring help, overloads, etc. The camper will weigh about 2800# to 3000# loaded, is my guess. The time for me to get to the wilderness is approaching fast and I would like to have an idea if I will need to spend extra money and time. The truck is 10,000GVW. It has the snow plow package so it has the heaviest front springs they make. All rear end suspension is factory with a tow package and no camper package. I will be able to weigh the rig in a couple of weeks but I do not want to be surprised. Any help please?
  • Hi......I have a 2014 F250 and I'm getting ready to buy a camper. What about air bags? Do they work good, or do the spring helpers work better?
    Bruce
  • We have a 2013 F-250 with Snow Plow and Camper packages. 10k pound GVWR. It has upper overloads from the factory and I added the StableLoad upper rubber blocks, first. Still, a bit of sag and side to side sway. I didn't find the amount of sag alarming, but the top-heavy induced sway was a little un-nerving. The StableLoads certainly engage the over-load leafs much sooner than the thin, stock pads, but with about 500 pounds in my truck (work stuff, no camper) it rides like a tank.
    Two weeks ago, before a 2,000 mile trip to The Keys, I installed the Timbren SES rubber bumpers, keeping the StableLoads, too. If I had it to do over, I'd install the Timbren SES, first, and see what happens. The sway was dramatically reduced after the SES install. Our camper is at least 3,000 pounds and we towed a cargo trailer that was about 3,000 to 3,300 pounds from Virginia to Daytona and back, driving to The Keys with just the camper. It handled beautifully in both configurations.
    I might remove the StableLoads and re-install the stock pads for the times between having the camper loaded. I may also install a set of F-350 axle blocks to give the rear an additional 2" or so of lift. I'm on the fence about the thicker axle blocks because I don't want my tailgate any higher during work mode. I use the truck for work more than I use it for the camper and trailer. With only the camper, I see no need for the F-350 axle blocks. Perhaps, re-aiming the headlights while trailering would be a better course of action than the taller F-350 axle blocks.
  • SuperSprings work in the same manner as the leaf springs on the F-350/F-450 trucks to support a greater load and to do so dynamically.
    The ones on my truck support a 3700 lb. camper load very well and do not make for a harsh ride when the camper is off the truck. No adjustments needed and nothing to wear out or break. Took me under an hour to install a pair on my truck.
  • Maybe. Get it loaded up first and do some driving around town.
    Be sure to stand well back of it and check for side to side leaning or sag. If the camper is heavier on the driver side or passenger side, you will need air bags to level it side to side.
  • If you don't have the over load springs (camper package)
    I would look into supersprings
  • Rather than guess: Get it, load it, see what it needs and THEN spend money. You can certainly make one trip safely.
    If things are so bad that you're afraid to drive it even once without adding a bunch of suspension doodads, you need a bigger truck.
  • Looks like 'dry base weight' is 1580#
    2014 F250 'cargo weight'.......from 1591# all the way up to 3807#
    Depending on which F250 (4X2--4X4, reg cab--crew cab, short bed---long bed, gas---diesel)
  • I would guess you will need StableLoads or additional spring support. Might check into Timbrens also. I would first load the camper and see what the result is first.
