EcoBullet wrote:
dacotahkid wrote:
According to spec my payload is 1801 lb appx.
No need to approximate. The yellow sticker on the door will tell you exactly.
I don't think this is quite true as it may have been correct when the truck left the factory, but anything added afterwards will subtract from this figure. Unless the truck is "exactly" like it was, the payload will definitely be less. This can be from a few pounds to several hundred pounds.
The only true way to find the actual payload is to get the truck weighed equipped like it will be when towing and then subtract that figure from the truck's GVWR.
Don't forget the weight of the WD unit and hitch head.
