KD4UPL wrote:
SoCalDesertRider wrote:
JoeChiOhki wrote:
Hydraulic if you can afford it :).
The PTO drive gear, controller and wiring, driveshaft, hydraulic pump, mounting and hoses to connect to the winch are pretty expensive to set up. Hydraulic winches aren't cheap either.
For something that may only be used a handful of times, if at all, in the life of the truck, an electric winch would be far more cost effective.
Now if it was for a vocational tow truck, then yes, by all means, get a PTO powered hydraulic winch system, it'll last a lifetime and pay for itself quickly!
Who said anything about a PTO? I agree that would be really expensive. I would go with a Mile Marker winch or equivalent that is hydraulically powered off of the power steering pump. I think I heard that all of the military HumVees have this set up. That's way better than adding extra batteries and huge 12v cables. As long as the engine is running you can winch and don't have to worry about battery drain.
If they have them that can run off the power steering pump, then hot dam, go with the hydraulic! I didn't know such a thing existed!
