Steve_in_29 wrote:
Also I believe the hydraulics have a tendency to let cable out before the brake catches once the pull is stopped. Which is why the Jeep Club that used to hold Panamint Valley Days wouldn't let a vehicle running a hydro winch participate on the Surprise Canyon run.
I don't think there is a brake. If the solenoids are closed no fluid moves and the hydraulics just hold same as a hydraulic leveling system.
Instructions do warn that if the engine is off and you use the control it will allow the drum to turn.
This is MM specific. There could be others that operate differently.
