acudr
Mar 12, 2014Explorer
Wind Generator?
Does anybody use a wind generator? Vs... solar? Has anyone already worked out the pro's - con's? Thanks,
KD4UPL wrote:
Wind isn't a good match for an RV. A typical wind turbine needs to be mounted at least 30' above anything within 500' of it. This is difficult to do on a portable basis at most campsites. Most wind turbines don't produce their rated power with less than 28 MPH wind. This is rare most places and unpleasant to camp in when it occurs.
The power available in wind is related to the cube of the wind speed. So, if you double the wind speed you get 8 times the power. This means that low speed wind really doesn't have enough power potential to bother with.
Combine all this with the noise and vibration a turbine would transmit to it's attached camper and it doesn't work out too well.
Solar is a much better solution for an RV.
